The new H4n recorder at DVinfo.net
All Things Audio
Old March 11th, 2009, 03:33 PM   #1
I just recieved the new recorder and used it on one wedding. I can't speak to the technical side, although I can say the recording results are very good to my ears, there are a two things I am a little disappointed with.
1) The rubberized body is just a coating of sorts. It looks rubberized, but does not feel that way. Just my opinion.
2) The recorder does not (at least I have not yet discovered it) allow for separate recording levels within the two tracks of the on-board mike or the imputs.
Bill Rankin
Bill Rankin is offline   Reply With Quote
Old March 11th, 2009, 05:38 PM   #2
Bill, thanks for the report - I wasn't aware that the H4n was shipping.
Right - I don't think the H4 allows different recording levels for each of the XLR inputs, and I don't really need it or want it for the built-in mics. But that would be nice to have on the XLRs...
Old March 11th, 2009, 10:36 PM   #3
H4n
In the MTR (multi-track recording) mode, each channel is separately adjustable: Page 42. Also, be sure to go to ZOOM and get the firmware update.
I haven't put the H4n to any difficult yasks yet, but it seems promising.
Chris
Chris Christ is offline   Reply With Quote
Old March 12th, 2009, 12:17 AM   #4
I know that in MTR each channel is adjustable, but I couldn't figure out how to start recording on all 4 channels at the same time.
Bill Rankin
Old March 12th, 2009, 12:24 AM   #5
for more info about this recorder
H4n Handy Recorder
Bill Rankin
Old March 12th, 2009, 09:31 AM   #6
So, if I'm using just the inputs, say a wireless mic on one, and a shotgun mic on the other, I can't control the levels on these seperatly? What I do to one I have to do to both?
Unless I'm in 4 track mode, which means only 16 bit, not 24bit, then I can do whatever to each track independently?
Old March 12th, 2009, 10:06 AM   #7
Anybody who has the new H4n - several of us would send very good thoughts your way if you would be so kind as to do a one-hour sync test.
E.g., run your camcorder, run the H4n at 16/48 or 24/48, audible slate, roll both for an hour, tail-slate, ingest to your editing system, and see how the marks line up in your NLE.
The original H4's clock wasn't good enough for long takes... Sure hope Zoom improved on the clock chip.
Old March 12th, 2009, 10:32 AM   #8
Dylan - I am still learning this H4n and so far, I have not been able to adjust the inputs individually AND record both channels at the same time.
I'll try to get a sync test done asap.
Bill Rankin
Old March 12th, 2009, 02:27 PM   #9
On the original H4 (firmware 2.20) you could separately adjust the recording levels of the two external inputs. It is in a menu however, you couldn't easily do it "live". It's more for fine tweaking in addition to the gross adjustment of the two external sensitivity switches. I feed mine with a mixer almost 100% of the time, so again it's just a fine tweak to match the output of the mixer. The few times I used just external mics hooked directly to the H4 I also adjusted these levels independently, but the material I was recording was pretty even.
Surely they didn't do away with this control on the new unit!?
Jay Massengill is offline   Reply With Quote
Old March 12th, 2009, 03:02 PM   #10
I have been working with the H4n and unfortunately, it appears to me, that they have removed the track adjustment feature.
Bill Rankin
Old March 12th, 2009, 06:41 PM   #11
I just completed a sync test with my camera and the H4n, and after one hour of record time there is NO noticable difference to the ear. Looking at the timeline waveform the H4n appears to be slower by one or two frames.
Bill Rankin
Old March 12th, 2009, 08:37 PM   #12
Does this recorder work for voice overs? I was looking at a ROPE podcaster but the Zoom H4n attrached me.
Old March 12th, 2009, 08:50 PM   #13
Sean, it records audio very well.
Bill Rankin
Old March 12th, 2009, 09:10 PM   #14
Interesting. How are the preamps?
Old March 12th, 2009, 09:27 PM   #15
I cannot comment on the technical side. I just know the sync is quite accurate and the audio sounds very good.
Anyone else?
Bill Rankin
