How do I get a clear frame grab? at DVinfo.net
Old January 16th, 2003, 05:44 PM   #1
I know this may seem like a basic question but I have never had to get a frame grab before. I am using Adobe Premiere 6.5. I tried using the STop Motion capture but can't get a clear picture I would assume due to interlacing. How do I "de-interlace" the still or video to get a clear still. I have after effects as well if this would help...
John Puffs is offline   Reply With Quote
Old January 17th, 2003, 06:38 AM   #2
Frame Grab
File-Export-Frame will give you a still image. Ctl + M is the shortcut, although it doesn't work for me. There is also a still export function in Advanced Windows Media if I recall correctly, one in which you can pick a file type. I believe you can also set a default for the frame export in the project settings. I deinterlace in Photo Shop when I do it at all. It depends on whether the frame is staying in a video project or going out in the big world.
David Hurdon is offline   Reply With Quote
Old January 17th, 2003, 08:00 AM   #3
Actually, the shortcut for a frame grab is CTRL+SHIFT+M.
fargogogo is offline   Reply With Quote
Old January 17th, 2003, 08:15 AM   #4
Frame grab keyboard shortcut
fargogogo
That would explain why CTRL + M doesn't work for me. :)
David Hurdon
Old January 17th, 2003, 09:10 AM   #5
Capt. Quirk
Just in case you may have overlooked the obvious, you need to have the desired frame under the timeline marker, cursor, or whatever it's called, ( I'm sick, and just too foggy to remember anything details clearly), then go to file-export-frame.
Keith
K. Forman is offline   Reply With Quote
Old January 22nd, 2003, 10:11 AM   #6
Photoshop has a de-interlace filter which works great on captured frames.
Rich.
Rich Kennedy is offline   Reply
