PC/HDV editing solutions, links and more at DVinfo.net
Old November 13th, 2003, 12:36 AM   #1
MPS Digital Studios
Post up ALL PC edit solutions and links, if applicable: Aspect HD, Premiere, Vegas Video, etc. And questions, too! And those in the know, post up answers!
Help out the PC folk working with HDV.
And of course, JVC's, which is a pain just getting the code key in! :-)
heath
My Final Cut Pro X blog
Old November 13th, 2003, 12:51 AM   #2
Canopus HD turn-key
Canopus Japan have an‚Žounced Hi-Def editing suite "HDWS-1000" which uses newly developed "Canopus HD Codec".
The specs are sketchy, but here is summary.
- Frame Structure; Intra frame compression
- Compression ratio; 1/7
- Resolution; 640x480 to 1920?~1080 (1080/60i)
Canopus also an‚Žounced their future roadmap of HD editing systems.
- HDWS-HQ (using "HQ Codec" for higher picture quality)
- HDWS-NET Station (network and XDCAM/P2 ready)
- HDWS-HDV (for consumer MPEG2 HDV)
- HDWS-Field (Laptop system)
HDWS-1000 prototype will be shown at Inter BEE 2003 Tokyo (from Nov 19).
HDWS-1000 prototype;
http://www.watch.impress.co.jp/av/do...2/cano3_03.jpg
Future roadmap of HD editing systems;
http://www.watch.impress.co.jp/av/do...2/cano3_08.jpg
Masa
Masahiro Kikuchi is offline   Reply With Quote
Old November 13th, 2003, 12:52 AM   #3
MPS Digital Studios
Here's one that interests Apple users with Vitrual PC, and I'm guessing will make PC users quite happy:
http://www.womble.com/
Not too pricey (Under $125) and can allegedly (more research needed) put HDV BACK to the HD10 and DVHS!
heath
Old November 13th, 2003, 01:08 AM   #4
CTO, CineForm Inc.
Info on CineForm Aspect HD can be found at www.cineform.com (check out the new website.)
Old November 13th, 2003, 08:53 AM   #5
MPS Digital Studios
Masa,
Does this turnkey HD system edit HDV?
heath
Old November 14th, 2003, 01:08 AM   #6
The turnkey have Their new codec, "Canopus HD Codec" as internal codec.
I assume the board on the system have HD-SDI I/O and you can feed uncompressed HDCAM or DVCPRO-HD signal through it.
I think you can transcode (recompress) MPEG2-HDV, then edit as well as other HD materials.
I still don't have detailed information about this system, but we'll have something more after next week.
Canopus is going to show some HD related systems at InterBEE 2003 (Broadcasting equipment trade show).
I can see another "HDWS-HDV" product name on their future plan chart. This might be a HDV based system.
Masa
Old November 14th, 2003, 02:34 AM   #7
MPS Digital Studios
THanks, Masa. What's your background?
heath
Old January 11th, 2004, 12:28 AM   #8
MPS Digital Studios
Don't forget about Adobe's Premiere and CineForm's AspectHD.
heath
Old January 11th, 2004, 12:51 AM   #9
Masa, any idea if this new Canopus system will be 1920 x 1080 24P capable?
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old February 3rd, 2004, 06:18 PM   #10
CTO, CineForm Inc.
CineForm's Aspect HD is now available for Premiere Pro to offer the industries highest level from real-time performance of HD editing, using the lastest and slickest editing application.
Also announced a couple of weeks ago is Connect HD an HDV accelerator for Sony's Vegas 4.0.
Read more at www.cineform.com.
Old February 13th, 2004, 12:43 PM   #11
MainConcept has something in the works for Premiere Pro. They call it Mpeg Pro and is supposed to edit Mpeg and MicroMV with FireWire preview. It will be available in an SD and a HD version. The website doesn't tell much but it's interresting.
http://www.mainconcept.com/upcoming_products.shtml
Martin Munthe
VFX Supervisor/DP/Director
Martin Munthe is offline   Reply With Quote
Old March 9th, 2004, 06:09 AM   #12
Stand by for DeckLink HD and Premiere Pro. Black Magic Designs has just released drivers for the DeckLink SD cards and they are going to release HD drivers soon. A DeckLink HD card is less than $2K and does uncompressed HD and Jpeg for online and offline in very small file sizes.
Dual Xeon and server class MoBo's with PCI-X required. I'd go for a Dell.
http://www.decklink.com
Martin Munthe
Old March 15th, 2004, 11:48 AM   #13
Premier Pro makes HD from numbered stills
I've been able to use Adobe Premiere to make 1280x720 WM9 HD content from still image time-lapse sequences. You can see a scaled down 5 minute clip here...
http://www.dogsleap.com/videos.cfm
I captured individual frames using a Canon G5 (five megapixel) still camera as 1600x1200 jpegs and then cropped to 1280x720 and processed using photoshop batch actions. I configured Premiere Pro to 1280x720 (Video for Windows editing mode) and imported each sequence as numbered stills.
Scrubbing in the monitor window isn't very smooth until after rendering for the first time, but rendering takes forever (about 6 hours for a five minute clip on my dual 2.8ghz HP). But once the first rendering is done, it scrubs fairly well.
I used Adobe Media Encoder to output a WM9 file 1280x720, 29.97, and bitrate settings set to the maximum (probably overkill) and the 5:20 clip resulted in a 390MB file. It plays beautifully on my computer display (Samsung 213T).
I used Cleaner XL to convert to mp4, m2v, and smaller wmv files.
So, it does work for time-lapse, but it's slow.
Mike
www.placerqatsi.com
www.dogsleap.com
Mike Posehn is offline   Reply With Quote
Old May 28th, 2004, 02:06 PM   #14
JVC HD cams and Vegas 5
Does Vegas 5 capture directly from JVC's HD cams?
I’ve never used Vegas but I use Premiere Pro a little at work.
How does it compare?
Roger
Roger Collier is offline   Reply With Quote
Old May 28th, 2004, 02:18 PM   #15
MPS Digital Studios
http://www.cineform.com/index.asp?Pa...PROD&ProdID=17
CineForm's Aspect HD supports Vegas.
hwm
