Brevis & Canon Eos Lenses at DVinfo.net
Alternative Imaging Methods
Old June 12th, 2007, 10:15 PM   #1
curious if anyone is using their brevis with Canon EOS ELECTRONIC Lenses. Meaning any canon lens that has an aperture which is controlled in camera through electronic settings. i am a still photographer, and own a lot of great Canon EOS lenses that work this way. hoping i can use them and not have to invest in manually controlled aperture lenses. also, if you are using the lenses that I have described, what happens to their aperture setting when you attach it to the brevis...do they automatically set to the lowest setting? any information would be great as i am about to purchase a brevis and want to know what sort of adapter to buy. thank you.
David Zaugh is offline   Reply With Quote
Old June 12th, 2007, 10:57 PM   #2
Jon (I think) on the Cinevate forum mentioned the work around for this is to put the lens on your DSLR, set the aperture and a really slow shutter speed. Take a picture and take the lens off when the camera is still taking a picture.
Sounds crazy to me not to mention a lot more work. I use manual Nikons.
Gene Crucean is offline   Reply With Quote
Old June 13th, 2007, 12:08 AM   #3
I bought used Nikons even though I have two Canon SLR bodies and a handful of lenses.
Jon Wolding is offline   Reply With Quote
Old June 13th, 2007, 03:29 AM   #4
Jon & Gene......
Thanks for the reply. Dennis Wood sent me a personal email as well answering all the questions I directed at him. I am ordering my Brevis tomorrow. I am going with the Canon EOS mount for starters, but have already started searching for some manual Nikon lenses on EBAY. Would you mind recommending a particular lens or two that really works well for you. I personally am a huge fan of the seventies style of filmmaking, and as a still photographer always lean towards longer lenses. I was initially thinking of getting a 50mm, an 85mm, and something over a hundred, like a 135mm or maybe even a 200mm. Have you used any longer lenses on the Brevis. Also, are you buying super old lenses or fairly new lenses?
If it is of interest, you can check out my website for photography. Under the personal section you will see stills that relate to my feature, THE MONARCH OF CRYSTAL FALLS.
www.zaughphotography.com
Thanks again for your help.
I look forward to posting test footage as it comes in.
Old June 13th, 2007, 07:20 AM   #5
e-mail eric birger at http://www.birger.com/ - he is working on one of these for the RED cam and canon eos mounted lenses and can give you more information, probably.
Old June 14th, 2007, 03:44 PM   #6
thanks for the info Meryem....the device looks pretty good.
Be Well,
David Zaugh
Old June 14th, 2007, 06:07 PM   #7
David
I checked out your site, very nice!!
I really like those Paris pictures,
what camera did you use? and retouch workflow?
well done.
e.
Sights Sounds Stories
www.tinboxtwo.com
www.reardenstudios.com
Eric Peltier is offline   Reply With Quote
Old June 15th, 2007, 10:30 PM   #8
I have a 20D and several EOS lenses and a Brevis. I also have a nice collection of FD lenses (I do not understand the fascination with Nikons as I feel the FD lenses give a more pleasing look). When I use the EOS mount, I have to put the lenses on the 20D body to set exposure, a real pain in general but many of the EOS lenses are pretty good wide open.
That being said, I rarely shoot EOS lenses anymore on the Brevis because I am in love with the FD look. I have a 17mm F4.0, a 28mm F1.8, a 50mm F1.4, an 85mm F1.8 and a 135mm F2.0 All are Canon except the 28mm which is a Sigma. What I DO like to do is to use the FD lenses on my 20D, you can buy an adapter for like $20. It gives you some funky diffusion and bokeh but I think they look awesome on the 20D.
ash =o)
Ash Greyson is offline   Reply With Quote
Old June 17th, 2007, 02:21 AM   #9
Ash
Any chance you can post some examples?
thanks
e.
www.tinboxtwo.com
Old June 17th, 2007, 03:36 AM   #10
Originally Posted by David Zaugh View Post
Jon & Gene......
As mentioned before it will be a right pain using Eos lenses with any adaptor. Not having control over the aperture will be quite a compromise. Look in the alternative imaging forums for more info about them.
Philip Bloom
Old June 21st, 2007, 05:14 PM   #11
hey
hey you know haywire (he's in one of your stills).
One of the guys from prison break...
Dante Waters is offline   Reply
