Soft Pouch recomendations at DVinfo.net
Old April 12th, 2007, 07:12 AM   #1
Could anyone recommend a soft pouch that the HV20 would fit in? I carry some canon DSLR lenses in there soft pouch cases and want to add my hv20 to the lot in my bag and wanted something simple and easy to remove. something without buttons or zippers is a plus but not required.
Thanks so much guys
Jason Brown is offline   Reply With Quote
Old April 12th, 2007, 12:27 PM   #2
The Canon lens bag for the 70-200mm f 4.0 should fit perfectly. I'll check it
out when I get home tonight and reply with a Canon model number...
Old April 12th, 2007, 05:00 PM   #3
Jason, The Canon lens pouch that fits the HV20 is the LP1219
you can find it at B&H photo by searching for Canon LP1219
Again, its nothing more than a lens pouch but will work perfectly if you want to use it to stuff your HV20 into one of the lens pockets for your SLR camera
bag... There are no parts on this bag that will scratch your cam.. pull strings for closure..
Good idea, and I'm sure I'll use that solution at some time....
I also purchased a Case Logic bag that I'm going to use to put the HV20 into
the center console of my truck. I wanted a little more padding around the cam for that. The HV20 fits into this bag like it was a tight fitting glove.
It has pockets for two tapes (one each side) and memory and extra battery (in the front pocket) and nothing more... so its very compact in size and good for protection. Also a belt loop.
If your interested in this bag also its the Case Logic SLCC1
you can search on B&H for info on this bag too...
They are about the same price range.
Old April 12th, 2007, 09:47 PM   #4
I have been using the Tamrac 5314 and it has worked quite well.
- Aanarav
http://www.sareen.tv
Aanarav Sareen is offline   Reply
