HV20 and Brevis35...first footage! - Page 2 at DVinfo.net
Old March 26th, 2007, 12:44 AM   #16
Hi Michael, don't worry for the spelling... Thanks for your answer ! Could you please explain the reason why you still prefer HVX200 ? The manual controls ? The gamma settings ? By the way, what do you think of the cine gamma of the HV20 ? It would be nice to see a comparison of the 2 settings in this little camera.
In the independant film-maker world you talked about, in which case you think the HV20 will have serious drawbacks compared to HVX200 ?
Thanks Michael !
Kristin Stewart is offline   Reply With Quote
Old March 26th, 2007, 01:23 AM   #17
Originally Posted by Michael Schoenfeld View Post
hello all,
Michael Schoenfeld here,
The lenses I tested were focused without and follow focus devices - just my hand turning the lens, so I do know what an "in focus" image looks like, it's just mighty hard to get it with any consistency by hand. and These are fast shallow lenses! That being said they are very sharp wide open, and that is how I intend to use them.
Neat little combo - looks really odd though.
All the best,
Michael Schoenfeld
Michael,
Thanks for the tests -
One of the daunting things using a 35mm adapter on any of these HD cameras is the crucial ability to focus with the viewfinder/LCD.
It looked like you were able to get it quite accurate, however.
So how is the LCD for focus?
John
John Benton is offline   Reply With Quote
Old March 26th, 2007, 11:56 PM   #18
John, I believe Michael did mention in his thread at the cinevate forum that he uses larger HD monitors for critical focus, and wasn't overly thrilled with the HV20 focus assist feature. I'll have the HV20 myself shortly and will be in a postion to at least compare it to the XH-A1.
Dennis Wood is offline   Reply With Quote
Old March 27th, 2007, 10:41 AM   #19
I own two HVX 200's that create a better image than the HV20
Are you sure? Taken the pics seen all over the place, I wouldn't say that 960 x 540 can be better than a true higher resolution device like this small HV20 really is.
Mathieu Kassovitz is offline   Reply With Quote
Old March 27th, 2007, 11:05 AM   #20
So it seems to me that this camera would take care of flip issue too. Set up your shot, then roll the cameral over and shoot upside down, or even learn to use it upside down. Seems like it might be light enough to hang of the back of the Brevis ? Comment from Mike or Dennis ?
Chris J. Barcellos
Old March 27th, 2007, 08:37 PM   #21
Chris, we already have a solution for inverted HV20 (or any other small cam) using our standard rails. It does not correct the LCD flip issue, but it will make monitoring with monitors like the Dell 24" LCD easier. Why doesn't an invert mount correct the onboard LCD? : http://www.maths.ox.ac.uk/~smithdm/upside.html
External monitoring with the Marshall HD 7" LCD is something I've accepted as part of the work flow. Even with the external monitor, the XH-A1's output of magnified footage (using focus assist) to the external port is a welcome aid when testing very shallow DOF options for the Brevis. Hopefully the HV20 will do the same.
Rails mounting with the smaller cams is a good idea as their plastic chassis' tends to flex a bit when racking focus etc. Back when I was using the GS400 a lot, I used it rarely off rails. What I found is that the entire rails/adapter/lens/camera rig can come off the tripod and be used like a fig rig. We're waiting right now for carbon fibre tubing done to our spec, so the rails rig will lose some weight very shortly.
Old March 27th, 2007, 08:50 PM   #22
Hi Dennis:
Yeah, I tried it with my FX1 and saw the issue. I use a magnet right side up and that works, but still have flipped image.
Chris J. Barcellos
Old March 27th, 2007, 09:39 PM   #23
Hi Dennis
Please post some clips asap. :-)
Also, a lot of folks are curious if the achro is needed.
Regards
JohnG
John Godden is offline   Reply With Quote
Old March 27th, 2007, 11:15 PM   #24
Ah, the achro. The HV20 surprised us by being the one and only 43mm lens camera that needs an achromat :-( None of the other SD/HD cams at 43mm or under have needed one. That said, we may be able to sneak by without one by tweaking the mount method. Until I get one in hand, I won't be able to comment further. According to the vendor, I should have the cam by next week.
Old April 20th, 2007, 05:13 PM   #25
Kristin, he's using EOS lenses. They use a servo controlled aperture which is locked wide open unless the lens is mounted on an EOS SLR.
This is not true. There are lens mounts which offer aperture control. I can't recall the names of the two companies I found which offer these, but they are out there.
Bill Porter is offline   Reply
