Collapsible double net backdrop? at DVinfo.net
Photon Management
Old March 9th, 2007, 12:50 PM   #1
Can anyone recommed a supllier of a collapsible double net, for backdrop purposes?
Greg
[UPDATE] by supplier I meant item info, I haven't been able to find a collapsible net backdrop
Greg Quinn is offline   Reply With Quote
Old March 10th, 2007, 02:06 PM   #2
Greg
Flexfill makes them and are available in sizes up to 60", B&H carry them for about $170. For the black net be effective you will need to place the net at least two feet behind the subject and use a wide aperture on the lens (low depth) or the net will show. Keep in mind that by the time that you fit a circle in a rectangle (TV) it will not longer be 60". You probably will restricted to shoot only head shot. I would recommend the 4x6 (used horizontally) or 6x6 ScrimJim from Westcott. BTW fiberglass screening material is an inexpensive option and will drop about one stop.
Nino
www.EFPlighting.com
Nino Giannotti is offline   Reply With Quote
Old March 10th, 2007, 11:30 PM   #3
Thanks Nino, your advice is very helpful indeed.
Greg
Old March 11th, 2007, 12:08 AM   #4
On Nino's suggestion I went looking around and found this...
http://www.qualitywindowscreen.com/s...b676e9f512ec3d
$57 bucks plus shipping, not too bad for a pretty huge backdrop... I can't imagine needing anything larger than this roll would give you. For the wider widths, search for "Pool Screen."
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old March 12th, 2007, 09:06 AM   #5
I buy this kinda stuff at dazian.com.... they do all the broadway theater fabs.
cool stuff!
widest loomed fab I've ever seen!
http://www.dazian.com/cgi-bin/page.p...=117&cat_id=45
Christopher Witz is offline   Reply With Quote
Old March 14th, 2007, 01:40 PM   #6
The Wescott Scrim Jims collapse as well. I don't know if that was clear or not, but I find the square/rectangular shapes much more useful than the round/oval Flexfills. Plus they tend to hold their shape better in a breeze.
Ralph Keyser is offline   Reply
