19 mm Sennheiser in 25 mm micro holder at DVinfo.net
Old December 20th, 2006, 12:24 PM   #1
How do I attach a 19 mm diameter Sennheiser MKH 418 in the 25 mm diameter micro holder of the A1? Is there any "professional" solution?
Michael
Michael Mann is offline   Reply With Quote
Old December 20th, 2006, 01:42 PM   #2
Gaffer's tape around the barrel.
Seriously. Can't get more professional than that.
Chuck Fadely is offline   Reply With Quote
Old December 20th, 2006, 02:05 PM   #3
This will be harder to come up with, but definitely cleaner than tape: find the right size rubber bushings. You'll need a couple of bushings, each with an inner diameter of 19mm and an outer diameter of 25mm. Will take some legwork and a trip to a hardware store or two, but it's definitely do-able.
Old December 20th, 2006, 02:13 PM   #4
Images: 4
Just an idea: in harware stores, you will find some slit foam tubes to insulate central heating pipes. I wonder if the right diameter is available...
Jerome Marot is offline   Reply With Quote
Old December 20th, 2006, 02:57 PM   #5
Thanks for all of your proposals. Foam tube or rubber bushings sounds "cleaner" to me than Gaffer tape.
Michael
Old December 20th, 2006, 03:53 PM   #6
mic
get some weather striping tape from hardware store.
its foam and sticky on one side, but is usually white if that matters
OR get velcro tape, its sticky on one side and soft fuzzy on the other, black, but doesnt come in different thicknesses
OR some places have foam cushion tape that you stick under vases and things so they dont scratch furniture
Rick Hensley is offline   Reply With Quote
Old December 20th, 2006, 04:07 PM   #7
the design of the holder seems odd to me but maybe there's a historical (or cost) reason for it.. not sure why it wouldn't open on both sides, with mutliple thumbscrews (2 with 2 pins, or 3, or 4) and just tighten down on both sides to accomodate a range of mike sizes..electrical tape on the mike was what I used but it lets the mike wobble a bit b/c it's narrow
Dave Stern is offline   Reply With Quote
Old December 20th, 2006, 04:38 PM   #8
Contributor
My old Sony mic fits perfectly. The Sennheiser MKH60 looks very slightly smaller in diameter; if I use it I can slip some doubled up rubber bands over it, and that should make it snug enough.
Old December 20th, 2006, 08:19 PM   #9
You don't like gaffer's tape? Ok, then try this: self-stick velcro; the soft "loop" side. I have a Sennheiser with gaffer's tape and a Rode with velcro. The gaff tape looks more professional but both work fine. Despite the costs, these things are just tools. Whatever works.
Old December 20th, 2006, 09:01 PM   #10
O-Rings
What do you think about these O-Rings from MSC Industrial Supply. They are $4.90 for a package of 100.
Inside Diameter: 0.750 In. (19.05mm), Outside Diameter: 1.000 In (25.4mm)
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=15678591
Sincerely,
Ken Boyer
Ken Boyer is offline   Reply With Quote
Old December 20th, 2006, 11:46 PM   #11
The thin grey foam that protects a Lowel light bulb inside its little cardboard box has worked fine for us.
We switched the stereo mic that came with the camera (thick barrel) for an AT short shotgun (thin barrel) and used a piece of that foam and it not only acts as a shock absorber, it also holds the mic firmly enough.
You could even double up (use two pieces of foam) if necessary.
Saved us a bunch of money, and looks really unprofessional:-)
Michael Knight
All media since 1960. Formerly CP16/Nagra. Currently learning F350/Fujinon HSs18 x 5.5BRM, Mac G5 Quad and FCP Studio.
Michael Knight is offline   Reply With Quote
Old December 21st, 2006, 12:23 AM   #12
I like the o-ring idea, no tape or glue required. Consider too that a low-temp silicone material will provide a bit of isolation from mechanical vibrations. Consider McMaster-Carr Part # 9396K31
A full shock mount (with the rubber-band suspension) would be best - Is the mic mount removeable?
Jay Fisk is offline   Reply With Quote
Old December 21st, 2006, 06:20 AM   #13
Is the mic mount removeable? Yes it is, see these threads:
http://www.dvinfo.net/conf/showthread.php?t=73144
and
http://www.dvinfo.net/conf/showthread.php?t=79638
Old December 21st, 2006, 06:56 AM   #14
Rubber bands
I like to just wrap a rubber band or two around the mike. Easy to remove and gives a little bit of vibration isolation. Use the wider size bands.
Rick
Rick Llewellyn is offline   Reply With Quote
Old December 21st, 2006, 08:41 AM   #15
I have an old foam wind shield that slides onto the mounting area of my sennheiser which compresses down nicley when clamped onto the Xlh1 and also gives a bit of protection to noise should you accidently knock that end of the mic
Regards
Mick
Mick Jenner is offline   Reply
