HDV file size versus DV at DVinfo.net
Old October 12th, 2006, 08:06 AM   #1
Does anyone have a comparison of a file size from a clip from an HD100 with a regular DV clip? I'm trying to compare for buying storage. Isn't the size of the files comparable to regular DV?
I wasn't sure whether to post this in the editing forums or not so if I should've please forgive me.
Brett Ward is offline   Reply With Quote
Old October 12th, 2006, 12:56 PM   #2
Native HDV1 (720P) files are actually smaller than their DV counterparts. HDV2 (1080i) are the same size.
DV uses 25Mbps (2.8MB/s), but HDV1 only uses 19.2Mbps (2.3MB/s.)
That translates to approximately 10 Gigabytes per hour for DV or HDV2 (1080i), but only 8.2 Gigabytes per hour for HDV1 (720P).
Tim Dashwood
Old October 12th, 2006, 05:47 PM   #3
I actually get closer to 13gb per hour for HDV 1080i.
Alex Thames is offline   Reply With Quote
Old October 12th, 2006, 10:22 PM   #4
Both DV and HDV record at 25mbps. Thus, one hour DV or HDV gives you about 13GB file.
Peter Robert is offline   Reply With Quote
Old October 13th, 2006, 02:04 AM   #5
Audio that has been converted to 48Khz 16-bit uncompressed probably accounts for the difference.
Tim Dashwood
Old October 17th, 2006, 03:29 AM   #6
DV and HDV 1080i 25 Mb/s
25 Mbits / second
25.600 bits / second
3200 bytes / second
3,125 Mb / second
187,5 Mb / minute
11,250 Gb / hour
if you get 13 Gb/hour it is probably because of the fact
1) Tapes are about 63 minutes
2) This is the actual size of files, size of files on a HDD might be different (1000 - 1024 difference: E.g. 1,5 Gb is not the same as 1 Gb and 500 Mb)
HDV 720p (19,7 Mbits/second with the audio included)
19,7 Mbits / second
20.173 bits / second
2522 bytes / second
2,46 Mb / second
147,75 Mb / minute
8,865 Gb / hour
So, taking everything in account, 1 hour of DV or 1080i HDV is about 11 Gb and 1 hour of 720p HDV is about 9 Gb.
But Brett, remember: if you should use Cineform for the HD intermediate codec, your filesize will shoot up to about 30 GB / hour for HD
Werner Wesp is offline   Reply
