Firmware based CFHD? at DVinfo.net
CineForm Software Showcase
Old March 2nd, 2005, 09:13 AM   #1
David
I am wondering whether a firmware based CFHD via suitable DSP with direct record to HardDisc would be possible?
I envisage a beachbox-sized unit which bolts on to the underside of an FX/Z with a D1/D4 input connector. Inside the box is DSP circuitry/electronics containing the CFHD algorithms and a 2.5" HardDisc 100Gb+. The box would have the facility for swapping the HardDisc - eject and replace.
The idea would be to directly record HD component to HardDisc as CFHD 4:2:2
Do you think it possible?
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old March 2nd, 2005, 10:21 AM   #2
CTO, CineForm Inc.
Yes I think it is possible although it would take quite a bit of work. We are doing embedded work using Pentium-Ms to do the compression. The interest is the 10-bit compression for this type for application.
Old March 2nd, 2005, 10:40 AM   #3
Well I hope you decide to move on this either yourselves or via sub-contracting the design and manufacture
Out of interest typically how many minutes of 10bit CFHD would fit on a removeable 2.5" 100Gb HardDisk?
John Jay
Old March 2nd, 2005, 10:58 AM   #4
CTO, CineForm Inc.
About 2 hours. :)
Old June 8th, 2005, 12:22 AM   #5
There is a lot of custom made direct to disk camera projects going on in the alternative imaging forums, so that would be a good place for your project. It requires a lot of work and money.
Wayne Morellini is offline   Reply With Quote
Old October 4th, 2005, 03:07 AM   #6
Hello, David.
Any news about "Firmware based CFHD"?
Serge Victorovich is offline   Reply With Quote
Old October 4th, 2005, 09:02 AM   #7
CTO, CineForm Inc.
There are two active projects for on-step CineForm Intermediate compression; we expect one of them to be annouced at the end of this month.
Old October 4th, 2005, 10:15 AM   #8
Thank you, David. Have seen information about Ingest Box
and now understand your solution. My thoughts just based
on yours information from this discussion board.
David Newman
June 13th, 2004, 10:52 AM
I believe it would possible to encode 1920x1080 camera feed in 10 bits (we haven't done 12 yet) at about 30 to 40 fps on a 3GHz P4, and 10 bit 1280x720 feed at about 70-85fps. I know there will be other overheads so these numbers could be high, but I still believe 1920x1080 @ 24p would be possible on a P4.
What is weight, size and power consumption of this box?
Old October 4th, 2005, 11:14 AM   #9
CTO, CineForm Inc.
Yet to be announced.
Old October 31st, 2005, 10:07 AM   #10
CTO, CineForm Inc.
The Wafian recorder has been annouced, I think the press release just went out. I still waiting for the story to hit regarding an on-set recording project and was about to be published. I'll give details when they happen.
Old October 31st, 2005, 12:14 PM   #11
Actually we made a decision to hold up the press release -- not for technical reasons but for coordination with some other near-term events. It'll go out in the next 1-2 weeks. In the mean time if anybody has any questions don't hesitate to drop us an email at prospecthdinfo@cineform.com.
David Taylor is offline   Reply
