4:4:4 10bit single CMOS HD project at DVinfo.net
Alternative Imaging Methods
Old May 10th, 2004, 09:09 PM   #1
ok new thread started,
What I am doing.
Taking a 16mm Russian film camera and converting it to digital HD 720p 60fps single sensor CMOS chip
Digital parts.
Taking a board camera with a Micron CMOS chip 1280x1024 10bit, and a frame grabber with CameraLink software/hardware and building a tiny PC to take on-set for image capture/record.
So far.
Getting test images from camera/chip combos to see what is the best design for this system. Looking at colors, saturation, contrast and dynamic range of the units.
Next steps.
Buy camera/capture board combo and order Russian 16mm film camera and start tests.
question, what is the mm of 16mm filmstock? is it really 16mm? is that wide? high? or diagonal? if it's 16mm diagonal then I need to make sure that my chip is no bigger then 16mm..if it was smaller it would have a crop factor...how would you deal with this for VFX shots that need camera tracking for CGI??
can anyone help me answer the questions above? also an update, looks like the raw electronics will cost $2500 plus a computer with RAID and the 16mm body....this will do 48fps so you could get 1/2 speed at 24fps playback...how good is 1/2 speed? Will I want more then that amount of slomo for "film-style" slow motion effects? I have never shot film so I don't know how slow 1/2 is..anyone?? I guess that is like taking 30fps and playing it back at 15fps right? but it will be smooth ;)
Obin Olson is offline
Old May 11th, 2004, 10:12 AM   #2
RED Code Chef
48 at half slow-motion is indeed 24 fps. Should look fine. You can
also write the capture software to just drop every other frame
and just write 24 fps to disk.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 11th, 2004, 01:14 PM   #3
very good, because of the rolling shutter artifact I will need to shoot no less then 48fps all the time to get rid of the artifact...
update:
trying to get the price down a bit for this "test" order ;)
test images..I will post them when I get home today
Old May 11th, 2004, 05:56 PM   #4
Hey Obin,
Saw you on the dvx100 conversion and smx camera threads and see you're going through with this. When you way shooting at 48 fps and slowing to 24 are you looking to play back in regular motion, just with better quality for effects, or are you just talking about just making a slow motion image for a visual effect. (May sound like a silly question, but don't know how you fx guys work). I shot a 16mm feature, so I know a little about it. However, I know very little about camera insides. So you're gonna make a 1 chip HD out of a16mm camera, huh? I've got a CP16 with 32 frame overcrank and an excellent Canon 12-120 zoom/macro focus on it. Can't get myself to well it cause it was my first feature camera, but maybe if I listen to you I can convert it. Of course, I'm shooting features, so I would need great storage. Are you still planning on getting one of the Summix cameras if they come out (not sure if their creation is official or what)?. All these camera mods get me so excited that I may actually be able to make/buy one soon and make flicks that stand a real chance of theatrical release. Keep us posted!!!!! Good Luck.
Laurence Maher is offline
Old May 11th, 2004, 09:36 PM   #5
Mr. Maher, are you from India? also I am not using sumix cameras I will be using a single cmos chip that can output 1280x720 for that HD standard....I will use the 48fps for slow motion effects...how slow does your 16mm look with it's overcranking?
Old May 12th, 2004, 04:18 PM   #6
Obin,
No, the name is of Irish descent, (you're talking to an anglo-mutt from Denton, Texas). It's not all that slow. I'm not sure what you need for fx work. This looks about like . . . ummmm . . . well, a little more than half speed. Good for dramatic effect when running, or in a kind of "character realization" state, or someone taking some bullets in the chest. . . if you remember back to Terminator 2, I think there's a scene that probably used around the same speed when Linda Hamilton is setting up Cyberdine to be destroyed, cops show up and start shooting at people. (I know I pulled that out of my butt, but where you guys think in tech, I think in scenes, etc.) Anyway, how's the camera coming thus far?
Old May 13th, 2004, 11:55 AM   #7
wow great test image today...I will try and post it up
http://www.dv3productions.com/test_i...00 Rebecca.bmp
Old May 13th, 2004, 12:08 PM   #8
Why are you using a 16mm film camera body? Lets see:
Film transport mechanism and gate : don't need.
shutter: don't need.
film magazines: don't need
What's left?
All you need is the lens, and lens mount part.
Perhaps it would be simpler to use a box with a lens mount on the front.
-Les
Les Dit is offline
Old May 13th, 2004, 12:35 PM   #9
I want the "film" viewfinder and a camera that is a "real" camera not a box with a lens! :) I DP alot for our company and I would not be seen with a box and lens setup on a big shoot ;)
oh btw that "test" image above is NOT a good bayer filter conversion...that is why you see all the jaggy's on the edges of stuff
and a 2nd test pic:
http://www.dv3productions.com/test_i...ncorrected.bmp
Old May 13th, 2004, 03:29 PM   #10
Obin,
(Call me Larry).
Keep me posted on the Obin-cam. I'd like to see the finished product. What cam's were you using to get true slow mo video?
Old May 13th, 2004, 03:59 PM   #11
I will start with 48FPS with this system at 1280x720 as a max frame-rate so I can still get 1/2 speed slo-mo at 24fps...after this tests out then I will buy a much higher speed framegrabber so I can do atleast 60fps ...looks like the order is going in today for the system!!! yahooo!!!! can't wait!!!
software guys are telling me that I can program the capture software to skip frames! this is REALLY good because it allows me to run the camera at 60fps all the time and avoid the "rolling shutter" artifact!!
The day of great chroma keys is nearing.....
the obi-oneCAM maybe? ;) LOL
Old May 13th, 2004, 05:04 PM   #12
to obin
obin, can you explain me who is the producer of that board camera you mentioned?
thank you,
filip
p.s.
your text:
Filip Kovcin is offline
Old May 13th, 2004, 05:25 PM   #13
Camera Choice
I have a K3 got it on ebay from a guy in Belarus. Shipping was a bit steep $60.00 but I got a pristine camera for $170.
The K3s are dirt cheap.
The American cinematographer's manual will tell you the exact aperture dimensions. 16mm is from side to side. The real difference is that some cameras the K3 included use film perfed at both sides.
Super16 has the film perfed on one side and the aperture plate is enlarged to take advantage of the additional negative space where the perfs were.
I'll go dig out my 12th ed. tomorrow at work if someone doesn't post in the mean time.
James Ball is offline
Old May 13th, 2004, 05:28 PM   #14
to obin - MICRON is ...
ok.
that was too fast, now i know that micron in obin's text is not anything connected with size or whatever, but the company name itself. ok. sorry.
so, the producer is micron.com. is this correct?
filip
Old May 13th, 2004, 05:32 PM   #15
yes
