Shooting in 3D with Two DVX100s at DVinfo.net
Old November 23rd, 2007, 04:49 AM   #1
I have been thinking about shooting a black and white monster movie in 3D with two DVX100s using the Anaglyphic method and Red&Cyan glasses (the cheap paper kind since I'll be buying 200 of them for a festival screening).
I will be producing a tripod mount for the two cameras making them spaced correctly and parallel so that they may pan on the same head. I need not zoom for the film.
Any thoughts, ideas, problems, or solutions?
I did just see Beowulf, and have no aspirations to make anything of that quality. We only have one projector, so the Anaglyphic method it shall be. Having a red tinted scientist absurdly point at the camera - popping off screen- while telling another character about something scientific, would do it for me.
edit: Wait a minute, theres a 3d SECTION!? WHERE HAVE I BEEN!?
DELETE
Bryan Mitchell is offline   Reply With Quote
Old November 23rd, 2007, 02:06 PM   #2
21st century 3D does this with the Andromeda-modded DVX100s. (But obviously not anaglyph.)
But then again, their rig might be out of your price range. It's rental only, and in the ballpark of $5k/day. One of their reps will fly out and help with the 3d stuff; I can't remember if you have to pay for their hotel+travel. Contact them for an exact quote... $5k/day might be off the mark.
2- A moderator will likely move your post, don't worry.
Old November 23rd, 2007, 02:31 PM   #3
Moved from Open DV to 3D.
Old November 24th, 2007, 09:00 AM   #4
Thanks Chris.
Glen, I don't know much about the mod, but the polarized method is pretty much out as a viable possibility given the venue and my budget.
Hopefully the DVX's are small enough to get close enough together for my use, but if not, I suppose I could always go with smaller less professional cameras.
Old December 16th, 2007, 01:46 PM   #5
Bryan,
I've done this before but we decided to remove the door/handle of the left camera in order to get them closer together. This was difficult and required the help of the service manual.
You may also want to remove the lens hoods, but they are still no where near the target interaxial distance of 65 or 70mm, but the effect still works. You may end up with a "hyper-stereoscope" effect if the cameras are too far apart. Some people like this. I find that it feels like you are much shorter than the actual tripod height when the lenses are too far apart.
We used a vacuum belt for synchronizing focus.
Tim Dashwood
Old December 19th, 2007, 06:07 PM   #6
Images: 1
Try the split-prism method. One camera mounted at 90 degrees to the other, aimed at a one-way mirror. the other camera is behind the mirror.
I wish I could locate a diagram or picture of the setup but it's relatively common and easy to achieve, and allows you to get both cameras' field of view as close as you want, right up to both cameras even getting the exact same perspective.
BenWinter.com
Ben Winter is offline   Reply
