PAL/NTSC question - A1 at DVinfo.net
Old October 24th, 2007, 08:40 AM   #1
I'm working on a project with the A1 - shooting in 60i (NTSC) here in the US. I need to send the footage to Denmark where they use 50i (PAL). I know I can upgrade my camera to shoot PAL, which I might do, but I need to know if I can send him test footage shot in 60i and have him be able to playback or capture from his camera.
Anyone know the answer to this? Thanks...
Philip Gioja is offline   Reply With Quote
Old October 24th, 2007, 11:07 AM   #2
Hi Philip,
As long as your friend's camera has the both PAL/NTSC capabilities then there is no problem, otherwise the answer is NO.
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old October 24th, 2007, 11:30 AM   #3
because you are shooting in 60i and not 24f, I'm sure he might be able to find a Sony Z1 that can play your footage.
David Chia is offline   Reply With Quote
Old October 24th, 2007, 12:53 PM   #4
Images: 4
A PAL canon A1 will not play NTSC material. Most if not all Sony camcorders will play PAL and NTSC material (but only record in their format of choice).
Jerome Marot is offline   Reply
