First shoot, first impressions for HVR-HD1000 - Page 5 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old January 15th, 2008, 05:05 PM   #61
They should have no problem working together. We have one hooked into our HD1000U at work. I havent grabbed the footage but I have recorded to the drive. Seems to work nice.
Greg Toope is offline   Reply With Quote
Old January 16th, 2008, 08:10 AM   #62
completely random, but can anyone confirm that the lens hood is fixed or removable? Thanks
Andy Salmons is offline   Reply With Quote
Old January 16th, 2008, 10:00 AM   #63
Thanks so much I was not sure if camcorder would control DR60 or not.
BTW: Hood is removable, with a sort of spring loaded locking knob.
S
Sara Jourhmane is offline   Reply With Quote
Old January 16th, 2008, 02:41 PM   #64
Can the screen flip out?
I have heard of other peole flipping the screen on other sony cameras and just using that as a the exposure etc. buttons. Will the screen flip out and lock in place for this? Still is a pain but might be the answer for some people.
Dan Gonzales is offline   Reply With Quote
Old January 22nd, 2008, 11:02 PM   #65
I have never used a camcorder with an eye piece viewfinder (don't know if that is what it is called). Anyone with glasses use the HD1000 yet and if so how is the viewfinder?
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old January 23rd, 2008, 02:28 PM   #66
Like most cams, you can adjust the eyepiece to match your glasses' diopter.
Old January 26th, 2008, 11:33 AM   #67
Hello,
That's it, I ordered in England, the FX7 to $ 3075 including delivery. I get the next week. Let me give you my first impressions.
I paid the FX7 in England, $ 200 less than the HD1000 in france!
Daniel Rabranque
Daniel Rabranque is offline   Reply With Quote
Old January 27th, 2008, 03:00 PM   #68
It Works for Me
I shot my first event last Saturday (a birthday party) and I can report the following:
The HD1000u is not the “retro VHS looking plastic camera” described by critics. It feels hefty and is made of high impact ABS plastic. Following the tradition of Sony it has a very appealing look. Since shoulder mount was a definite necessity for my business it has proven an excellent choice. The shoulder pad must be adjusted to your needs to be able to balance the weight, the camera tends to be a bit front heavy but nothing like the Canon XL2 which has made my right arm grow larger than my left. I added an additional 1/8 inch thick rubber pad under the shoulder pad to alleviate hardness. Contrary to opinions I had no problems with the hybrid LCD menus or focusing with the EVF. I found focusing comfortable even in low light. As an amateur event videographer I’m yet to find a perfect camera for low light conditions (within my pocket’s reach) so I was not expecting much and as such I’m always depending on my trusty custom on board light that possesses a 10, 20 and 50 watts setting. I have no problem convincing anyone for the need of extra lights even demanding “Bridezzilas” or stubborn Clergymen. As mentioned before I own the Cannon XL1s, the XL2, also the Sony HVR-A1U and HDR-HC1, and although the HD 1000u cannot give you the rich colors of the Canon XL2, or the manual selections of the A1U, the HD footage when down converted gives you better definition than the XL2. I remedied the lack of XLR by the acquisition of an XLR adapter and a better quality shotgun mike. An extended range battery is a must and also help with the camera balance and you HAVE to get the ubiquitous AC/DC battery charger. The main reason I acquired this camera was because my hand held cameras and the front heavy Canons where killing me in long takes. Some times tripods where not feasible and I had to use the dreaded camera mounts but they were also prohibited in some instances. At no time I got this camera because it “looked” professional. In my part time business I deal with people on a one on one basis and the professionalism is established by the way I conduct myself but, then again the looks of the camera do help.
The birthday shoot was a success, I’m in the process of editing the footage and so far it looks great. I wish this camera had A LOT of additions to facilitate my work, but then again, I’m not willing to pay the additional cost, so leave it the way it is.
I shot my 1st wedding in 1968 with a Bell and Howell 306, today I maintain the tradition of all amateurs: Within the limits of my budget, I make any camera work for my needs.
Maximilian Pinedo is offline   Reply With Quote
Old January 28th, 2008, 10:03 AM   #69
Thank you
You are not an amateur at all.
You are a true PRO since you are actually working with what you have, and as a true Pro you are working within the gears limitation .
Remember, that English is my second language.
Hans Ledel is offline   Reply With Quote
Old January 28th, 2008, 04:52 PM   #70
Just received the Sony Wide Angle adapter. A distinct improvement in shooting interviews in cramped situations. Only drawback so far, You can't use the lens hood and put the lens cap on at the same time. If someone would make a rubber lens cap to fit over the hood, all would be solved.
Old January 28th, 2008, 08:06 PM   #71
Just out of curiosity, which function you folks have choosen for the manual ring?
Old January 28th, 2008, 10:31 PM   #72
Exposure mostly. Focus when the camera is having problems due to low light. I have been using the spot focus function with good success.
Old January 29th, 2008, 11:02 PM   #73
Good to be here
Hi guys. I've been reading and learning from you the past week as I "found it" by chance. I'm from Brazil and I just got my HD1000U from B&H last friday. I shot a birthday party on saturday with nice results. Too good switching from a DV standard resolution HC96 handy (handy!) cam to the HD1000U.
I have to say I'm kind of shy as I read so many really professional talking around. But, well, I'll give it a shot and maybe at least get the conversation going about this good camera for the price.
I posted some clips of the party I shot over rapidshare. I think it's a good way to see what the camera does in real situations. Special clues about low light condition (clip number 4) and the Smooth Slow Recording feature. Well, you can see it without any compression, which I think it's great. Well, there it goes.
A. 480i
1. http://rapidshare.com/files/87368732...iente.avi.html
2. http://rapidshare.com/files/87368338...tural.avi.html
3. http://rapidshare.com/files/87367833...tural.avi.html
4. http://rapidshare.com/files/87394866...20dw2.avi.html
B. 1080i
1. http://rapidshare.com/files/87379799...iente.m2t.html
2. http://rapidshare.com/files/87380243...tural.m2t.html
3. http://rapidshare.com/files/87378840...tural.m2t.html
4. http://rapidshare.com/files/87393768...20dw2.m2t.html
Smooth Slow Rec: http://rapidshare.com/files/87394190...owrec.m2t.html
Thank you for everything I read so far. So good to learn with you guys. I'll come back soon.
Came back to edit this one just to add that clips 1 and 4 were made with the usage of a HVL-20DW2 sony light.
And also: sorry for my poor English - sometimes you'll have to guess what I wanted to say. :)
Tiago
Brasilia/DF
Brazil
Last edited by Tiago Cardoso; January 29th, 2008 at 11:07 PM. Reason: Forgot about the 20DW2 light info
Tiago Cardoso is offline   Reply With Quote
Old January 30th, 2008, 07:44 PM   #74
What is the front thread size and overall diamater? If the size is the same as the Canon wide angle lens then this might be a good solution http://hv20.com/showthread.php?t=1754
Any idea how the quality of the Sony wide angle lens compares to the Canon WD-43 or Raynox 6600 Pro?
Old January 30th, 2008, 09:37 PM   #75
37mm thread.
I can say from experience that the Sony brand Wide Angle adapters are better on their cameras than most other brands.
William Hohauser is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
