Shooting in HDV for SD - Page 2 at DVinfo.net
Old February 20th, 2008, 02:10 PM   #16
Screenshots
Okay, the first image was shot in DV and rendered in DV.
The second image was shot in DV and rendered out to SD Quicktime H.264
The Third image was shot in HDV and rendered in DV.
The Fourth image was shot in HDV and rendered in SD Quicktime H.264.
The last two images are the most telling since the first two, being shot with DV look nearly identical (I.E. the softness is in the source), though the second file is probably a bit softer. However, the second set of images shows that bypassing the DV Codec entirely results in a perceptibly sharper image. At least it does in Premiere Pro CS3. Anyone else have this experience? Thanks.
P.S.
The difference is even more pronounced when they're moving.
P.P.S.
There's now a second set of the same images in Jpeg format for those who want to open the images in their browser.
Shooting in HDV for SD-cofp_dv_in_dv_out.bmp   Shooting in HDV for SD-cofp_dv_in_qt_h_264_out.bmp
Shooting in HDV for SD-hoodoo_hdv_in_dv_out.bmp   Shooting in HDV for SD-hoodoo_hdv_in_qt_h264_out.bmp
Shooting in HDV for SD-cofp_dv_in_dv_out.jpg   Shooting in HDV for SD-cofp_dv_in_qt_h_264_out.jpg
Shooting in HDV for SD-hoodoo_hdv_in_dv_out.jpg   Shooting in HDV for SD-hoodoo_hdv_in_qt_h264_out.jpg
Get rid of the "Aspiring" in "Aspiring Filmmaker." Shoot it; you're a filmmaker. After that you're just negotiating your budget. (James Cameron paraphrased)
Alex Chamberlain is offline   Reply With Quote
Old February 27th, 2008, 11:00 AM   #17
Alex,
You did a great job of capturing the down-conversion between codecs perfectly. Do you have any screenshot comparisons of faster motion?
H.264 is vastly superior to the DV codec in Premiere, but your examples really vividly display it.
I'm pretty sure Premiere CS3 doesn't have it yet, but I wonder if the ProRes 422 codec can produce a better image, or whether any difference isn't noticable...
Ryan Postel is offline   Reply With Quote
Old February 28th, 2008, 10:19 PM   #18
I don't really have any faster motion captures. This shoot was pretty much all stationary shots of the talent in front of landmarks.
