Raid or more Ram? - Page 2 at DVinfo.net
Old August 15th, 2007, 07:50 AM   #16
Yes and Yes, and you can switch back and fourth from mt2 and smaller dv files anytime throughout to see whats happening on the full size files.
Chris Klidonas is offline   Reply With Quote
Old August 16th, 2007, 01:29 PM   #17
wow
dang... that sounds like a great app.... and seeing DSE's tutorial on it makes me want to give it a shot.... too bad I don't have any HD footage yet.
Jason Robinson is offline   Reply With Quote
Old August 16th, 2007, 01:34 PM   #18
I just would like to know how one goes about adding plug-in effects to their original HDV footage using GearShift. This might not seem like a big deal, but when you have a large project on the time line, with many cuts, that include numerous plug ins through many shots, it seems like it might get complicated. No?
Glenn Gipson is offline   Reply With Quote
Old August 16th, 2007, 01:52 PM   #19
wow
duplicate post
Last edited by Jason Robinson; August 16th, 2007 at 01:54 PM. Reason: duplicate post
Old August 16th, 2007, 10:39 PM   #20
Glenn:
There are two functions of GearShift:
(1) It makes it easy to create proxies of m2t clips.
(2) It makes it very easy to switch between the m2t clips on a timeline and their DV proxies you made in step #1.
GearShift is essentially a script that swaps an m2t clip with the equivalent DV clip. It does this automatically for every clip on your timeline.
You do not have to render DV proxies in step #1. You can tell GearShift to render to any file format for which you have a codec. I've played a lot with the PicVideo Mjpeg codec, but concluded recently that the proxies are just not as easy to work with as plain ol' DV. The problem with DV is that going from NTSC DV to MPEG2 (for making a DVD at the end of the process) really kills chroma resolution, so in my final MPEG2 render I use the m2t (HDV) clips as the source. PAL DV doesn't have this issue--you can render to MPEG2 directly from the DV proxy.
GearShift also automatically handles the color space conversion between the HDV world and the SD world. Finally, it builds proxies in the widescreen format, so the resulting proxy looks nearly identical in the preview window (just a very slight horizontal shrink, and, of course, a large difference in sharpness). Every dissolve and color correction made to the proxy will be automatically made to the HDV source upon shifting back.
My first big project years ago was done with DV using Pinnacle's Studio7. Back then (2001) a 40GB hard drive was really BIG. In order to fit my entire project into it, I used a similar proxy process in Studio7. On final render, the program would tell me to load a particular DV tape in the attached camcorder, and it would spend an hour shuttling back and forth, finding the equivalent DV master for the lower-rez proxy on the timeline. It was a fascinating process to watch.
Keep in mind that there is a price to be paid for using GearShift--you need to render additional files, and that takes time and space. Still, I can set it up to render away while I'm off doing something else. No big deal.
Richard Iredale is offline   Reply
