"No Communication" in FCP at DVinfo.net
Old November 26th, 2006, 02:43 PM   #1
Contributor
I don't THINK I've got any FCP settings wrong, but it's very possible. Same for the A1. But it's the first time I've tried to do anything in HDV. FCP is saying "no communication" when I go to capture mode. I'm at the 1080p24 setting in FCP, 23.97 sequence. In the camera the downconvert is off as required. There's video coming into the computer but no control at all.
Old November 26th, 2006, 02:49 PM   #2
Images: 1
Bill, check your device control presets. There are variatons of FW control and you may not have the right one selected.
Just a thought...
-gb-
Old November 26th, 2006, 02:50 PM   #3
Contributor
I checked that and think it's the right one. Unfortunately I'm at home now and can't tell you which ones I tried, but I believe I went through all the HDV ones.
Old November 27th, 2006, 09:34 AM   #4
I dunno if it helps but i was having problems getting my PC to work with my A1. I was plugging it into my front IEEE cables. I unplugged my external hard drive and plugged it into the rear one and now totally works. My guess was that just using one of my firewire was the solution. I doubt it helps but I understand the headache you are going through.
-Jimmy
James Jackson is offline   Reply With Quote
Old November 27th, 2006, 11:22 AM   #5
Similar Problem
I had a similar problem.
I managed to solve it by finding some App on the Apple Discussion boards that allowed me reset FCP to it's factory settings. I setup the defaults again and voila it worked.
It's called FCP Rescue 5 and can be found at http://fcprescue.andersholck.com/.
Hope this helps.
Scott
Scott Audette is offline   Reply With Quote
Old November 27th, 2006, 02:14 PM   #6
Go to Audio/Video settings and "Create Easy Setup" and go for the HDV settings. This worked for me as opposed to manually changing things around.
Larry Huntington is offline   Reply With Quote
Old November 27th, 2006, 05:08 PM   #7
Contributor
I did an easy setup, but what about Device Control Presets? What's that supposed to be for loading 24F?
Old November 27th, 2006, 10:03 PM   #8
Try these...
Sequence Preset: HDV - 1080p24
Capture Preset: HDV
Device Control Preset: HDV Firewire
Old November 27th, 2006, 11:21 PM   #9
You have the latest version of FCP right? I figured you did, but just in case...
Greg Rothschild is offline   Reply With Quote
Old November 27th, 2006, 11:39 PM   #10
Yes Greg. FCP 5.1.2 running on a Quad Xeon Intel Mac with the latest firmware.
Old November 28th, 2006, 08:20 AM   #11
These are generic tips that I'm sure you've already tried, but I'll put 'em up here for others:
First and most important, when you change settings in FCP, you have to open a new project for them to take effect.
Second, the camera has to be plugged in and on before starting FCP.
Third, I'm sure you've unplugged all other firewire devices to see if it works then? No firewire hub, right?
Fourth, (with a new Mac Pro, this isn't a prob,) some versions of Quicktime (7.1.1 specifically) broke the capture control.
good luck
Chuck Fadely is offline   Reply With Quote
Old November 28th, 2006, 09:07 AM   #12
Contributor
Thanks for all the posts. I'll work on it some more when I get time (shoots going on the next few days). I'm fairly confident that what I did was not have the camera turned on and switched to the proper mode before I opened FCP. Simple thing but I forget about that because my normal work mode is to flip the breakers that turn on all the decks and monitors before I ever turn on the computer. I had the camera plugged in but turned it off (I always power down before unplugging any firewire thing even though allegedly you don't have to--I've seen too many fried drives) and moved it to the front firewire port so I'd have easier access. I think when I powered the camera back up I did not restart FCP. So I'm fairly sure that's the issue, since I was getting video into the system, just no control buttons.
Old November 28th, 2006, 05:00 PM   #13
New A1 User Same problem
Hey all,
I just got an A1 and I'm having the same problem. Shot some test footage in 24f mode, and I can't get FCP to see the A1 with the HDV1080p24 Preset. I'm still testing through the different possibilities, but if anyone has been successful in capturing 1080/24f footage to FCP 5.1.2, would y'all mind confirming the settings you are using?
Thanks in advance.
Juan Diaz is offline   Reply With Quote
Old November 28th, 2006, 09:05 PM   #14
I don't have the A1 just yet, but thumbing through the FCP options, it seems as though you need to make a new device control preset under FCP menu > Audio/Video Setup
The "HDV firewire" and others are set to 29.97 fps, you'll have to duplicate that and change the frame rate to 24
See if that helps at all
Nick Weeks is offline   Reply With Quote
Old December 3rd, 2006, 11:29 AM   #15
Contributor
I'm still having trouble getting FCP to recognize the camera.
Here are my settings:
Camera is on Ext. Cont., HDV24F
FCP 5.1.2:
Capture Preset: HDV
Device Control Preset: HDV FireWire Basic (tried HDV Firewire too)
Playback Output Video: None
Playback Output Audio: Default
Edit to Tape/PTV Output Video: HDV (1440 x 1080) 24p
Edit to Tape/PTV Output Audio: Default
In Device Contro Presets I have the frame rate at 23.98. I tried 24 too.
Nothing works.
Bill Pryor is offline   Reply
