NAB2001: MarzPak Camera Suspension System
Jacques Merser is one of my like-minded cohorts on a large digital video mailing list, and he's also a fellow tradeshow trooper whom I keep bumping into around the country. Jacque's MarzPak is an interesting alternative to the expensive Steadicam-style support systems floating around.
The cool thing about the MarzPak is that the entire weight of the camera is transferred to your back, the strongest part of your body. The cable is spring loaded and maintains constant tension for steady shots. Here Jacques is pushing the camera down to shoot at a low angle. This is much easier on your arms than having to constantly hold up the camera.
From behind you can see the utility of the backpack. There's room back here for extra batteries and gear, allowing for all-day shooting. You can also see why I like to call Jacques "Cap'n Hook."
A detail of the quick-release camera mounting sling. A review of the MarzPak recently appeared elewhere on the net; I'll see if I can get permission from the author to run it here on the Watchdog. I think the pricetag is around $300 USD and you can contact Jacques Mereser at jacques@marztech.com.
Shoot-out between a pair of XL1 innovators... Jacques Merser on the left meets Karl Horn on the right. The MarzPak website is at www.marztech.com.
The Watchdog notes: Please be advised that I've tested none of the products on this page personally, and have not had business relations with any of the aforementioned companies. Proceed at your own risk... these images are meant only to give you an idea of what's available out there, and should not be construed in any way as a product endorsement. If you do contact a company based on what you see here, please tell them the XL1 Watchdog sent you (I could really use the reference). For information concerning Watchdog product reviews, manufacturers are invited to contact me directly at chris@dvinfo.net.
Back to the Image Gallery Menu
Thrown together by Chris Hurd
©1998-2008 DV Info Net
San Marcos, Texas
Don't tell me about business! I sold raincoats for thirty-five years!
