Guide to XL1 & XL1S Lens Options
an article by The Watchdog
Here is a brief summary of the various XL mount lenses available for the Canon XL1 and XL1S. Remember that all XL lenses will mount to either camera. Personally I have not had the opportunity to check them all out for myself, but I have included links to user reviews where they exist (lens attachments such as wide-angle adapters, filters, matte boxes, etc. are not included; hopefully they will be the subject of a future article).
Lens focal length equiv 35mm max ap filter remote
Canon 16x 5.4 - 87mm 38 - 620mm f/1.6 72mm yes
Canon 16x 5.5 - 88mm 39 - 624mm f/1.6 72mm LANC
Canon 3x 3.4 - 10.2mm 24 -  72mm f/1.8 72mm LANC
Canon 14x 5.7 - 80mm 41 - 577mm f/1.6 72mm no
Fujinon 14x 5.5 - 77mm 40 - 554mm f/1.4 62mm yes
Fujinon 12x 3.8 - 45.6mm 27 - 328mm f/1.4 82mm yes
Canon EOS f.l. multiply x 7.2 for video varies varies no
Canon 3D 7.5 - 22.5mm 54 - 162mm N.A. N.A. LANC
Canon 16x Manual   appx $1750    manual-only XL lens
A new 16x manual lens is available separately. Outwardly this lens appears similar to the previous 14x manual lens (which it replaces) in that it has a black barrel marked with focus, zoom and aperature numbers. This lens has a rectangular hood instead of the round one found on the older 14x. However, the primary difference between that lens and this new manual lens (other than the longer focal length of 16x) is a motor for zoom control from the grip, plus automatic iris control and two built-in neutral density filter settings (2.7 and 5). This lens may be operated in full manual mode, or switched to motorized zooming from both the grip handle and the LANC jack with a remote zoom controller (you'll need a separate remote focus control which connects directly to the lens). There is no automatic focus on this lens; it is manual focus only. It does not have image stabilization. This is not an "internal focus" lens; however, the front element does not rotate, which means clamp-on matte boxes may be used with ease. There's no iris ring, either; exposure is controlled by the dial on the camera body. The 16x manual lens is of course backward-compatible with the older XL1. For more info, see
    The Canon 16x Manual Servo Zoom Lens by Ken Tanaka.
Canon 16x IS II   appx $1600   included w/standard XL1S kit
Included in the basic XL1S kit (and available for separate purchase) is the new IS II 16x automatic lens. Outwardly it looks identical to the previous XL1 16x lens, but inside is a new design which reportedly is a significant improvement over the earlier 16x automatic lens. The new IS II lens is backward-compatible with the older XL1, and like its predecessor, it includes a neutral density filter, a maunal/auto focus switch, and Canon's superb Optical Image Stabilization technology. Like the one it replaces, this newly re-engineered lens is servo-controlled even in manual mode, with free-spinning focus and zoom rings without stops on an un-marked barrel. You can tell this lens apart from the old one by the red lettering marked IS II around the front filter thread. Of course it's backward-compatible with the older XL1. Like the older 16x automatic lens before it, the IS II has the extremely slow low-speed crawling zoom which isn't available on the 16x manual lens.
Canon 16x   appx $1600   included w/standard XL1 kit
For a majority of XL1 shooters, the 16x lens which comes with the camera is the only one they'll ever use. Some professionals were disappointed to find that it's not marked in the traditional sense with focus, zoom and aperture settings. That's because it's a vari-focus lens which is primarily automatic in nature with provisions for manual operation. However, even the manual settings are controlled by internal motors. In my opinion, this lens is excellent for what it is intended... all-purpose outdoor shooting, with a built-in neutral density filter and perfect for hand-held use thanks to Canon's excellent Optical Image Stabilization (this and the newer IS II are the only OIS equipped lenses available in the XL format). For more info, see these related Watchdog articles:
    The Standard 16x Lens Skinny from The Watchdog,
    Understanding Canon's New Way to Focus by Scott Barber.
Canon 3x   appx $1350    wide-angle automatic XL lens
One significant disadvantage of the standard 16x lens is its inability to get a sufficiently wide angle. Wide angle shots are extremely important for a number of applications, from filmmaking to journalism. Canon's 3x wide angle lens is an important tool for any serious videographer, allowing the XL1 to shoot in tight spaces such as small rooms and vehicle interiors. The camera gets closer to the subject, improving the audio quality from the on-board microphone, and wide angle shots in general have a significant appeal which other lenses can't obtain. A neutral density filter is included, but not image stabilization; it's not really needed, anyway. Like the 16x lens, this is a vari-focus lens and operates automatically with manual overrides. A very short zoom range is the only disadvantage, perhaps requiring a frequent changing of lenses as shooting circumstances dictate. For more info, see
    The Canon 3x Wide Angle Zoom Lens by Jim MacAllister.
Canon 14x   appx $1100    manual-only XL lens
Realizing the success that Optex had with their Fujinon lens conversion to an XL mount, Canon has followed suit and developed their own professional 14x manual lens. It does not include image stabilization, a neutral density filter or zoom and focus motors, but does provide complete and precise manual control of focus, focal length and aperture settings. Such controls are analog (instead of digital) in nature and are operated mechanically (instead of electronically) via traditional lens rings which will be familiar to professional videographers. Unlike the Optex-converted Fuji 14x, this lens communicates electronically with the camera head, allowing for certain digital effects such as the slow shutter speeds. However, in my opinion, it has a major drawback in that remote zoom and focus controls are not available, to the best of my knowledge. It seems as though Canon has undermarketed this lens... I have not yet had a detailed user review submitted to me; therefore, I can't tell you very much more about it.
Fujinon 14x   appx $1250   manual-only XL conversion
About a year before Canon released their own manual lens, a company called Optex (based in the UK) modified a 1/3rd inch Fujinon 14x lens to accept the XL mount. The result was a professional quality lens which provides smooth, all-manual operation. This is the same lens that's packaged with the Pansonic AJ-D215 and JVC GY-DV500U professional camcorders (it's a 1/2 inch mount on the JVC). The lens hand grip which houses the zoom motor had to be removed, to allow the lens barrel to clear the XL1's own hand grip. However, remote zoom and focus controls from third-party manufacturers can be mounted to the tripod pan handles, negating this drawback. One important disadvantage of this lens is that it cannot electronically communicate with the XL1 camera body; therefore, certain digital features such as the slow shutter speeds are unavailable. In my opinion, this is made up for by the quality of the Fujinon glass and the availability of remote lens controls.
Fujinon 12x   appx. $2300   wide-angle manual-only
This is a 1/3rd inch wide-angle lens intended for the Panasonic AJ-D215. In my opinion, it could become a superb lens for the XL1 if someone would be willing to convert it to an XL mount, as Optex did with the Fuji 14x. This lens has about half the focal length of the Canon 16x but four times the zoom range of the Canon 3x, making it suitable for both wide-angle and telephoto work. Not only would shot set-ups go faster, but the need for a wide-angle adapter would be eliminated as well. Like the Canon 14x and Fuji 14x, this lens would function as manual-only (the lens zoom motor would need to be removed for the lens barrel to clear the XL1 hand grip). However, a remote focus control is readily available, and presumably the Optex motorized remote zoom control for the Fuji 14x could be adapted to operate this lens. The price suggests that it might be prohibitively expensive for most folks; but I imagine that the cost might come down somewhat if Fujinon could be persuaded to sell the lens without the zoom motor/hand grip. I would like very much to hear from anyone who manages to procure, adapt and use this particular lens with their XL1.
Canon EOS series   photography lenses w/EF adapter
By using the optional EF adapter, you can match your XL1 to any one of the huge assortment of Canon EOS photography lenses. Since these lenses are designed for 35mm still photo cameras, and because the XL1's image plane is only 1/3rd inch in size, there is a magnification factor of 7.2 applied to the focal length of the EOS lens. For instance, if you mounted a 100mm EOS lens on your XL1, the effective focal length works out to 720mm, which is a longer telephoto shot than the standard 16x video lens is capable of. When you use Canon's really big EOS lenses, such as the 400mm, 500mm and 600mm lenses, the resulting magnification is like turning the XL1 into a telescope... perfect for some limited applications such as surveillance or wildlife videography. It's also possible to mount a wide-angle prime lens, combined with a wide-angle adapter, to achieve a medium focal length video lens with the quality of Canon EOS glass. For more info, see
    African Wildlife through an EF Lens by Jim Kinsey,
    Some 35mm Canon EF/EOS Lenses at Canon USA.
Canon 3D Concept   appx $8500    limited production
Project cancelled prior to production run. This lens was a concept proposed by Canon in September 2000; however due to manufacturing impracticalities, it has been officially discontinued and is not available. Undoubtedly the few working prototypes which do exist are now in the Canon Lens Museum at corporate headquarters in Japan. Some details from the initial press release:
"The Canon 3D zoom lens... features a built-in focusing unit that uses triangulation to measure the distance to the subject and a motor that adjusts the mirrors inside the left and right lenses to set the angle of convergence automatically, enabling even novice users to create 3D videos as easily as they would any ordinary video. Equipped with a high-speed shutter, the lens enables the camcorder’s CCD to capture the left and right parallax images alternately as a field image at 1/60th second intervals. During the 1/60th of a second when a parallax image is being captured, the corresponding shutter is open while the other shutter remains closed, preventing the image from being recorded. This alternate image-capturing process is repeated each 1/60th of a second so that 30 images are taken through each of the left and right lenses per second for a combined capture-rate of 60 field images per second. During playback, the left and right parallax images are output alternately in the video signal."
Back to the XL1 Articles Menu
Thrown together by Chris Hurd
©1998-2008 DV Info Net
San Marcos, Texas
Just because I don't care doesn't mean I don't understand!
